I hope you wear a backpack every time you ride
What type of screws would I need to go into those inserts?
Sorry I didn’t saw that I post the imperial one, if it could be easier, these are using metric screw from M4 to M10 but I suggest to use the M4 Ones
metric for the win
Thanks. I have to use the US Amazon though. I couldn’t find it in my app. I found this T-Nut 1/4"-20 x 5/16", (100 Pack), By Bolt Dropper, Pronged Tee Nut. For Rock Climbing Holds, Wood, Cabinetry, etc. https://www.amazon.com/dp/B01MSVU3WF/ref=cm_sw_r_cp_apa_yvazAbAEE1ZZA I’m just bad at understanding the measurements. Like what size screw fits inside. I’ll do a Google search lol.
If you use T-nut you need to drill a hole through the board.
Edit: here is the link for Amazon.com
I rarely see links from Amazon.ca here, I thought “hey cool !”. But then I tried to order, product will arrive between Feb 9th and March 2nd. No thanks
Back to the topic, I’m thinking of using insert nuts. I have one question though
- Should the insert nuts always be inserted from the top of the board and go through it ? Or can I just drill from below and put the insert nut from there ? Do you recommend using any sort of wood glue or anything to make sure the inserts won’t move ?
jsut make sure that piece of tape sits rock solid on the drill, mine didnt and now i have a few holes in my deck XD
LHB prefers paint seems sensible, is it a holey pro now so?
You guys realized there are things called drill collars right? Lol these don’t come off like tape and ruin your work…
I just drill blind
You can…with a depth collar… Thats my point lol
its probably somewhere in my 10000 items tools shed … oh wait. i dont have a tool shed
Should get one of those… I’ve spent thousands on tools just so I don’t have to pay someone else to do something…
Tools always resurface to use even if you only purchased them for that one project…
yeah but storage doesnt. i allready have a locker full of tools but sometimes you just wanna build stuff and if something is missing you just gotta improvise.
nah nah nah… I do it full ghetto. I just mark the spot to drill and hope I get the depth right
never failed so far
I know…I was just really going the :blind: route
Just what I have been looking for. Cheaper than a drill press.
i don’t have to remove a paint dot to use the bit for something else, a paint dot costs like a millionth of a cent, and a paint dot won’t rub the wood when if gets down to the line. I have bits with multiple dots on them in different colors, each one at a different depth for a different task.
