TWO Of these bad boys just arrived by in the mail
Paging Psychotiller??? Where are you??? Need me some trucks and mounts for these things
Be careful with the settings on those maytech vescs. I would recommend very conservative settings in BLDC to avoid cutouts and dead electronics.
Vescs I have are from torque boards if that’s what’s your referring too? Haven’t had an issue yet and have had them at very conservative settings
Anyone know where psychotiller is? Holidays ? Not answering emails it’s been weeks man
Hey guys can you chase this up for me again I still need to replace my 6355 cans the request number is #11287. My remote has died now the stupid charging port broke off:flushed:
Ok so starting death sled phase two I am going to build an enclosure for my VESCs’ remote receiver out of carbon fibre
Started mocking up from some old skateboard decks and my slide saw… aim is to try take the sharp edge away at the front a little
Finally got these in the mail they are sexy as f$ck took 6 weeks to finally arrive. Will take some getting used to these weird hangers that tighten from the outside. First problem is my maytech motors have only 26mm of axle but should be able to make it work. May need to turn down some spacers a bit more to get the pulley in as close to the truck mount as I can.
These mounts look bullet proof
Have started ordering some stuff to reterm my Maytechs to 5.5mm bullets to suit the TB Vesc’s
Found a good eBay supplier in oz if you guys here need these
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F323648416493
Also got some better hardened bolts for motor mounts in oz from these guys with a bit more length
And some 10mm sealed bearing which look pretty good from these guys in Oz too
My 97mm wheels look small now with these trucks
First of all thank you to @DexterEsk8 for coming through and sending me some replacement cans mentioned earlier in this story
Can’t say enough about torque boards they are awesome although I have run into one snag the 55mm cans have grown somewhat to the originals
The can now rubs on the inside it’s about 2mm too long now…will have to work out a spacer for them
I did notice they have improved the glue and the retaining ring is definitely bigger
Second try at carbon fibre…I’m fucked if I can get the bag to seal but anyways
Looked like a disaster when I first got the mould out but I think it’s Gonna be ok with a few coats of clear…you can see the raised part on top is where the suction was in the bag
niiiiice guz.
Looks good like you say, with a little finish, it will be ok
Stalking me old mate!? Gonna turn that bubble into a G for guz 🦳
haha you wish. I’m here to learn how to waste a disposable income
I hate this stupid enclosure how it’s sits up so far I’m gonna router down the centre a bit and try get it to sit flatter
I hope you mean youre gonna take it out of the enclosure and not the board… cutting tool on a dremel might be easier
Nut gonna burn a hole in the deck with my router… well that was the plan
#fibreglassitchisbad
Going to have to take off heaps to even get a small reduction at the edges
