I dont see any specs listed anywhere and don’t have much knowledge of the backfire brand other than the fairly typical budget board reviews and complaints.
I thought I’d share because I think the all terrain hub/direct drive is interesting. It kinda just looks like hoverboard wheels.
Anybody have more information about this board?
Oh very interesting, If the price is right, I might go for it. I was waiting for the all terrain hub for long time. although, the tire is too thin. I guess we have to wait until launch date
Does look like DKP . Hopefully for them they use a higher quality esc this go around. Their 2nd gen dual esc was crap, it would heat up and pins would separate
i wouldn’t mock it tooooo hard. We have a belt driven 4WD on 10" tires with similar trucks on a Tronix type board with 4 800 watt brushed inrunners. IT will climb a tree, stairs, and launch up a damned grassy knoll out of a dirt pit.
If these motors are sufficiently low enough KV, then upping the voltage would probably get you the same kind of performance we’re getting out of our older belted variant.
Also with hub, there is barely any drag when you let go off the accelerator. however, that was on 80-90 mm wheels and not all terrain. I am just assuming that the same physics apply more or less.
