when i try to do a motor configuration my vesc will blink red a couple time and i get an error saying bad motor detection and when i typed fault in the terminal i get fault code none, need help, thanks!
Really hate that win10 trunks the real time data window… (not your fault, just bitchin’)
Plz explain your setup, pics would be great also
I
am running 2 3s batteries 5000mah batteries in serious and TORQUE ESC VESC ® BLDC Electronic Speed Controller and also Electric Skateboard Motor 6355 260KV all from diy electric skateboardsorry if you cant read what i wrote but im am running 2 3s 5000mah bateries in serious and TORQUE ESC VESC ® BLDC Electronic Speed Controller and also Electric Skateboard Motor 6355 260KV all from diy electric skateboard
@bdemissi Do you have (2) 3S plugged into the VESC in series? Are your battery start/end cut off settings correct for your battery?
