I don’t know of anything else.
Switch the phase wires from the working motor to the currently not working speed controller. Run detection etc and see if it will spin properly.
Did you mange to solve the issue @WolfKnight? My VESC has the exact same symptoms: giving any throttle results in the motor jittering, red light flashing then a FAULT_CODE_ABS_OVER_CURRENT
error.
Using the keyboard keys (while connected to the BLDC Tool) also results in jittery/stuttering motor spinning. Running a motor detection fails. I have tried 3 different motors so it’s not a motor issue. I’ve also tried different firmware without success.
It was running perfectly until yesterday morning when it just stopped for no reason.
