I have a hobby charger in which I want to connect two connectors of 5s so 10s in total.
I don’t have the right leads I have only ones that fit 3s, so I can either make 5s out of what I have which may be problematic or order the right ones…
How bad is it if I charge my batteries without balancing for a month? (until the new cables arrive)
If they are already low than it’s highly recommended that u get soon, but if it’s sort of in the middle like let’s says 36-38v should be ok but I would keep an eye on them just in case
I forgot to say, it’s 18650s and charged them separately so they are all fully charged now. Maybe during this month I could now drain the batteries all the way…
But if it is bad I’d just try to improvise a connector for the hobby charger and order in the meantime while doing the build.
Sounds good, I guess I will either just connect the wires to the cells in the meantime and will only assemble things together until the 5s leads arrive, or even try to improvise and turn a 3s plug to 5… need to do some fine cutting…
I personally think you would be best to wait. There is no point trying to charge your batteries without the right connections, it is highly likely you will make a mistake and fry your pack.
