Hello builders, I have a 10S2P lion, which cell have 2200mAh and 22C constant. I have 14/42 gear ratio and have 82mm wheels. motor is 270 Kv. Do you know how I can calculate the theoretical value of max speed, time running, max distante… have a site that can make the calculation?
Yes, just search esk8 calculator in any search engine and there are several results that should help you!
Damn 1s faster than me
Your 10s2p can’t be 22C constant discharge, that would be 22*4.4=96.8A
Usually Street boards are ±10wh/km, off road are 20wh/km. So in your case 4.4A10s3,7=162wh
ýes you right XD 22 A not C
