I’m going on vacation but won’t be able to bring my board with me I’ll be away for, give or take, 4 weeks.
How should I leave my batteries? Should I fully charge it before I go? Should it be disconnected from the ESCs? Is there a certain way of keeping it in storage safely? It’s a 10s5p 30q pack.
1month is okay for a battery. I have cells who are laying here for more then 3 months. They where 3,45v. I think they are now 3,35v. Let me check it tommorow.
@AlanZhou, I said a good BMS. So fatboy doesn’t count because it’s neither. Let’s take a Bestech BMS as an example. It says it takes 50uA(~ for 10S battery) current draw to function. Say you want to allocate 1Ah of your 10Ah battery to BMS, it’s going to last you 1Ah/50uA = 1,000,000/50 hours = 20,000 hours = 833.33 days. If you want to have a factor of safety of say 2,5, or even 10, you are good for 3 months. A little bit of math, helps . Let me know if I have made calculation mistake somewhere.
Yeah I could see why that would make sense. All my packs have been shipped fully charged. I’m sure there’s a time table where it makes sense. Thanks for the correction!
Have you been using it regularly? Does it have a loopkey that disconnects everything? If the answers are both “Yes” then just ride it once to get it between 25% and 70% charge, and leave it. If they aren’t both “yes”, please elaborate.
I have a vtc6 10S5P pack and left it for about 5.5 weeks. I left it plugged into my unity and worried about that parasitic drain. Contacted Jeff (@Deodand) said don’t sweat it; it is designed for it.
6 weeks later I check my voltage and it didn’t drop at all… stayed steady at 36.7
