Hi there builders, first post after scouring here and google for answers.
I’ve started working my electric longboard over two years ago, but I had to put it on hold.
Finally got some more free time and made some progress, just currently stuck on wiring the battery/BMS and stuff.
The BMS I purchased only has C and B ports and most I’ve seen have P and B and/or C from other diagrams I looked around here. With that, I also trying to charge/discharge through the BMS. Would like to see if this is correct with diagram.
I did the balance wires already. Any other thoughts and feedback would be appreciated too.
Thank you.
combo list duplicate remover
cminus is neg, not pos. batt pos goes right to charger. Fuse cminus.
