So here’s the deal…
I bought two 5s 5000mah batteries with 5.5 mm bullet connectors to connect in series.
I also bought a VESC and a pre-made series battery connector (both with XT-90 connectors), and a 1-6s lipo balance charger that unfortunately came with an XT-60 connector. (Photos below)
I’m confused. How are you planning to connect your batteries to the series adaptor? The first link you posted are just the XT90 plugs, they wont do anything for you unless you solder them, they are not plug and play.
It’s kind of an given that you have to learn how to solder if you want to get into DIY electric skateboard. Like you, when I first began I had no soldering skills but after a few failed attempts. I kind of got the hang of it. So don’t want money in buying all these connectors. Do it yourself…
Please don’t use adapters… That doubles the chance of it coming unplugged and either starting a fire or injuring you from sudden loss of power… Just order the xt connectors and learn how to solder them on.
