hey, just drained my batteries for the first time and realised my battery indicator says 100% all the time, maybe its my wiring-idk. I’ve got another thread on my wiring, and the indicator i have is the same as MBuilders in december 2016. thanks
what kind of battery indicator you have ?
2016-Battery-Capacity-Tester-Indicator-for-12V-24v-36v-48v-CAR-Lead-acid-lithium
did you setup it ?
? what do you mean?
ok, mine goes up in 1c 2c etc. what does it mean
sorry that was stupid - it means cells. idk how to set it though
open your board, and at the same time press the button behind the board… and then you should be able to to see L3 and go press that button until you see L… 10 I guess…
a bit confused. their is no L1 or L2 etc
sorry but i’M confuse as u are… Just keep up whit the l10
okay i just figured everything out and it works BUT, the indicator is all over the place saying 63, then 80, then 58. realy quite wierd, maybe because its cheap
