I’m about to do my 10S4P custom build and I want to add the TorqueBoard On/Off Power switch, but also I would like to add the charging port and the battery indicator.
10x 5.5mm 2.1mm Female DC Socket Power Plug
36 - 42V Battery charger
Battery Indicator
TorqueBoards Power Switch
What would be the proper wiring to use with this options? I guess I should install the charging port right next to the battery since I would be able to charge the battery with power off (No risk).
Yes. But check the wire colors compared to the neg and pos written on the back of the monitor itself. My harness (or whatever) came wired backwards. No damage, but it wouldn’t work.
