I’m trying to connect this battery indicator to my batteries set up in series, but it keeps showing up as 100% when connected to the output end of the series connector when the two batteries aren’t even close to 100%. What did I do wrong?
Have you set it to 6s?
yes I have. the output is around 24.3v
So the display reads s6 when you go to the programming function
I had no idea this had a programming function. That seemed to do the trick. Thank you.
