Hi i have made my battery pack of 50 LG HE4 batteries. I have them in a 10S 5P configuration ending up with max 42V and 12.5Ah.
I have a 10S 60A Suunpower BMS, which i have connected the right way to the pack. The battery leads reads the right values from 3.6V up to 36V
I have also bought a 42V 4A power supply, With a fuse.
I have the two connected via a XT-90 Anti Spark plugs.
My problem is that the pack wont charge.
The powersupply blinks when red to green indicating that the power is cut. I can measure it goes from around 4A to 0 and over and over again. So something is wrong.
I can press the XT90 connector half in and the power will flow constant with 1A. But then the XT90 will get hot, so i pulled it fast.
I can not seem to figure out what is wrong. I have bought and changed the BMS, no smoke or nothing comes from it. So i think it works.
Can it be the resistor in the XT 90 that makes it work weird or what can i do?
I never heard of using an anti-spark connector to connect your charger to the battery.
It may be messing with the charger’s sensing circuit.
The charger negative to the bms P- pad
The charger positive straight to the battery positive
Usually, people wire a DC connector that matches the plug on the charger
Hi everyone, after months of waiting for new bms, then seeing that it was not a problem with the BMS. i bought a new charger and now it charges flawlessly. But weirdly enough with only 1 Amp but the charger is 2A
