I am trying to figure out all I can about dual vescs.
Which ones can support four wheel drive? Can you please give the vesc’s specs. Aka what voltage and amps they support. How fast I can push my board. Basically trying to figure out how big of a battery I can create with a given vesc?
I believe the flypsky 6.xxx can be wired for 4 wd. Is there any other vescs that support 4wd?
Is you question about battery configuration or vescs? I don’t get it.
You can use any Vesc and just connect two in the front and two in the back via CAN, both the front and back with their own receiver. Most Vescs max out at 60v (12s) and <100A, the 75/300 can do 75v (16s) and 300A.
Battery depends on your motors and how much you want to push them. Also which cell your will use. Anything from 8p to 12p could be reasonable.
I named the post battery that fits vescs specs.
The 2 different battery diagrams I set up are 720 watt hours. 12s 3p
The other set up I have is 840 watt hours. 352.8 volts I think it’s 21s 3p
all esc are good up to 10s, some are good up to 12s and only few are good up to 13s. please do not use 21s battery, you will destroy your vesc immediately. also 21s battery can’t output 352.8 volts, you got something wrong here?
as for cells in parallel, only limit is how many you can fit on your board
21s would be 77.7v. I am not aware of an esc that can handle that.
The natural choice would be 12s. And 3p is way too low for a 4wd setup, even with high discharge cells. Think about it, even with 35A per cell, that is only ~26A per motor (absolute maximum). If you dont want to use toy motors you will need 8p+.
You didn’t upload any pictures btw, you just posted links to your private google drive that noone can access.
So I am going to have 2 batteries and 2 vescs. 12s 6p. The diagram has 6 negative batteries facing up. then 6 batteries connected in series. Then then 6 batteries on the bottom with positive facing down.
I changed my mind I am going to split them into 2 12s 3p.
What do you mean parallel is the limit? Series should be the limit?
I am not sure, either I am slow or you are writing a lot of confusing and contradictory things. Do you want 12s12p? 12s6p? 21s anything? 3p?
Also what even is the question here?
Please be concise about what you have and what you want.
@curtis if you have enough space, go with 12s6p samsung 30Q battery. That will be 778Wh battery. It will be enough even for 4WD. If you have more space and money, go with 12s7p or 12s8p. Anything bigger than 12s8p will only fit in custom top mount box or Lacroix deck and enclosure. There is no need for further philosophy.
I would go with 12s 3p one battery then 12s 3p another battery and 2 dual vescs. How far distance could I push on average with a 12s 8p setup 4 direct drive motors?
you don’t need two batteries for 4WD, you can wire two connectors out of battery or if you gonna use anti spark, you can wire two connectors in Y (parallel) after anti spark.
you will have range anywhere between 30-90km on 12s8p.
You said 3p gives low amps per motor, but keep in mind you have 4 motors. On a 2wd setup each motor would ask say 40 amps for hard acceleration for example. To get the same acceleration on a 4wd setup each motor would only need 20 amps.
Anyhow, get two dual vescs or four single vescs, Doesnt matter which ones as long as its not flipsky. You can connect two duals with canbus i believe, or connect em all with ppm splitters.
As far as batteries go, A 12s5p would probably be okay. But if you got the space and money for it you can go for 12s8p or something like that. You don’t have to max out on the vesc specs because you’re probably never gonna draw that much.
