Hi everybody, I am selling some parts, the parts are new and never used (changing from idea 6s->10s) Shipping cost are for buyers, I live in Belgium, If you want something do me an offer!
Parts: 6s charge adapter: Working Temp/humidity:-10°C-50°C,20%-90%RH Storage Temp/humidity:-10°C-60°C,20%-90%RH Charging Plug:US/EU/UK/AU plug we can offer Charge port:DC Optional Safety standard:CCC/CE/UL/FCC/RoHS Input Voltage: 100—240V Output voltage: 25.2V Output current: peak 4A; Frequency:50-60HZ
UBEC Power Module 2-6S 5V/3A and 12V/3A (for lights) Dimension: 25 * 20 * 6mm (without cables) Voltage input: 2-6S Voltage output: 5V/12V switchable Current output: 2A Color: Red Net Weight: 7g
JST-XH 6S TO 2x 3S BALANCE SERIES
RC Lipo Battery Low Voltage Alarm 1S-8S Buzzer Indicator Checker Tester LED Use for 1-8S Lipo/Li-ion/LiMn/Li-Fe Voltage detection precision: +_0.01V. Unit voltage display range: 0.5~4.5V Total voltage display range: 0.5~36V 1S test mode voltage range: 4-15V Low voltage alarm mode for 2-8S Alarm set value range:OFF~2.7~3.8V Size: 40mm x 25mm x 11mm Original box: NO Net weight: 9g Package weight: 15g Color: Red
Update: I have also a 6s BMS it is this bms: http://www.benl.ebay.be/itm/321790634514?ul_noapp=true
