Basically I just finished putting together my first build and span it up for the first time. And to my dismey it seems that the belt doesnt sit right on the wheel pulley and it shakes quite a lot.
Every half turn on the wheel pulley it seems to go slightly out of allighnemt and the belts’ teeth get pushed up and eventually move back into place one set of teeth behind. (I have no idea how to explain it properly)
The closest thing that describes what I am seeing is that the belts pitch is wrong and every now and again moves one tooth back.
I am using : http://uk.rs-online.com/web/p/products/0183215/?tpr=2 http://uk.rs-online.com/web/p/timing-belt-pulleys/2865815/ http://uk.rs-online.com/web/p/timing-belts/4746485/
I am quite lost and need help. esk8 forum, your my only hope
