So I’m about to switch my gearing ratio from 14/50 to 14/36, also switching to Kegel wheels.I want to save a few bucks and get my belts from another site rather than Enertion (but I will be buying the 14T pulley from them). Only difference is the teeth on the belts. They’re both 9mm wide, and are 265mm in length, however Enertions has 55 teeth, and the other site has the same belt but 53 teeth.
Does this make a difference? Will it matter much? Should I just get the Enertion one?
