So I just got my board up and running after months of part failure and now I’m facing an issue with belt shredding. For the past day or two, when I hit the throttle my motor would make that cogging sound but not at startup (I know that can be fixed with a sensorred setup) but if I get moving and then go full throttle before I pick up enough speed. The same has almost always happened when braking. Breaking for me has always been super loud, but has also always worked. The cogging has gotten louder and more obvious so I feel like the issue is getting worse.
Perhaps I don’t have the belts tight enough? But the loosen up so much after just a little bit of use. Or maybe too much strain on just one motor?
It took me .2 miles on a new one before it shredded.
Any suggestions? I have a single 6355 190kv motor from Diy and ride the hills of San Francisco (working on adding another one)
