Hi! I got two turnigy motors: https://hobbyking.com/en_us/dt6376-14p-sensored-motor-125kv.html, dual Vesc setup, and the M1 battery: https://www.inboardtechnology.com/products/powershift-battery
What should be the right amps settings?
Max motor amps: 45 Max battery amps: 10 Max battery discharge: 10
I’ve:
Wheels: 90mm Gears: 36T/16T Battery: 43.2 nominal, 49.2 peak Capacity: 97Wh 2.25Ah
Is that right?
Thanks!!!
