I will be using a “Drok” Voltmeter on my eboard , it can be powered direcly from the battery from to 3-30V,…
but i will have 10S battery pack so 42 Volts .
Where is best place to Tap into to get 5V to power my Voltmeter?.., i’m using the Vesc and the GT2-B Reciever.
isnt the point of the voltmeter to show you what your batteries are pumping out? connecting them to anything other then the battery leads would give you a read out of that source so in your case a constant 5V, you would no longer know how much juice you have.
I just got these guys but I have yet to test them. There are some sbecs on hobbyking that will suport that 12s lipo… but there are multiple reviews on the page stating that they will die. So I went with these dudes, especially since they offer a 12v version as well
For the confused: that type of voltmeter needs a separate power supply, not just the voltage you’re measuring. You can’t just tie both together because the measuring range is higher than the max allowable supply voltage.
For @Randyc1:
There’s a 5V supply on the VESC, it’s on pins 1 and 3 of header P3 : schematic
It can supply up to 1A but be very careful not to short it or you’ll blow the DRV8302.
If you are not confident with attaching to P3 just take your power from the same pins your receiver is using. You can use a servo Y lead. It’s rated at the same 1A - its the same power source I believe. Your volt meter will use a few milliamps to power itself.
Yep - there are three pins for the receiver connection + - and signal. Red, Black, White(or orange). You want the red and black. You are not technically tapping into the receiver - you are tapping into the VESC 5v power rail
Your volt meter, as you have discovered, will have three wires - red and black for battery / ESC main power connections and another low voltage white wire for powering the LED display - this is the one you want going to the VESC receiver + pin. No need to run the earth here. YOu are getting that from the main battery black and red wires.
White goes to the main battery supply.
Black to any earth - either the main battery, or the earth on the receiver input pins on the VESC.
Red (to power the meter) goes to the live 5v pin in the receiver inputs on the VESC
Yes !, i got 5v to power the Voltmeter from tapping into the reciever’s (+ & -) ,…then 3rd wire (white) on the Pos side of my battery pack to read voltage of pack ,…works perfectly.
