I’ve got a 10s bestech BMS with an e-switch. The current switch I’m using is a big BMS one from existing which is rated at 6a. What’s the minimum amps I should be looking at? I want to buy a smaller replacement to suit my new deck and enclosure.
Could be right. I once where asking about the voltage for the e-switch but I can’t find the mail with the answer anymore.
Maybe @Namasaki can say you what voltage usually used for the e-switch.
Or just write a short mail to Lucy
[email protected]
The usually reply very fast.
I plan to fit it into the side of the hunmie deck and 16mm is too big. I was going to use that one and then I saw the momentary one which was smaller. I’ve been struggling to find one the right size!!
