I pot my receivers in silicone, sticking them anywhere isn’t an issue
You could ask them to make a grp enclosure to fit their board?
I would strengthen where the antenna exits the reciever as well if you are going to mount it externally,it’s a well known weak point!
Sent out an enclosure to the US today. Managed to get shipping for £13.
Lol who’s duck tape enclosure was that? I’m still building my v2 board just want 2 focbox’s to finish it off!
Erm… That would be me. Impatience and all that. Now where would you get some focboxes from??? Here’s my next build in component parts.
Now to make a custom enclosure.looking good ben!
This is something that might be handy eh? You’ve shamed me into getting out there and measuring up… I’ll get onto it.
meant no shame BenBro… just constantly looking at my options
and you sir are one o’them
Ha, ha. I wanted to ask as well, but wasn’t sure if the info was out there somewhere already, and I’d just missed it.
I’ll get onto it this arvo. For the Tesseract, that one internal is 450mm x145 and either 37mm or one under construction is 27mm.
Yep that one is 540mm x 145 x 40mm internal. I also do a 30mm version. I’ll try to get a single sheet with all sizes. Cheers @WARMAN
Drill a small hole in the deck like 1mm and put the wire thru, close it with some hotglue and put the wire under griptape Thats what I did
- Modelled on the Landyachtz 9two5 540mm x 145mm x 40mm Available in gloss without logo too.
- Landyachtz evo specific. 640mm x 140mm-175mm x 25mm
- Modelled on random curve… 215mm max x 145mm max x 40mm
- Modelled on Truncated tesseract. 450mm x 145mm x 37mm (also soon available in 25mm)
- Flat. 215mm max x 145mm max 55mm (available 315mm long too)
- Modelled on the Landyachtz 9two5 260mm x 145mm x 40mm
- Modelled on the Landyachtz 9two5 deck 540mm x 145mm x 30mm
- Not pictured. Modelled on the Landyachtz 9two5 deck mm 320mm x 145mm x 40mm
I can supply various widths and thickness of adhesive backed rubber seal. I’ve been talking to a supplier who can pre apply dry reusable locktite to the mounting screws and am shortly getting a sample.
