The dude is my personal.
Is that a 18s battery? Beautifully constructed as usual. I’m guessing 4p.
Yes but 8p
Shoot. I’ll definitely be visiting the site and recommending you for batteries for sure.
Question:
Whenever you’re making a battery of higher amps/current, do you double the nickel welds? Or just keep it single .2mm welded depending?
I’ve seen battery makers work, but I’ve never gotten that answer for myself.
I generally don’t like to stack nickel as the second layer welds will usually break or come apart much easier… having a higher voltage pack actually cuts down on the ampacity required not add to it which seems backwards I know.
Thanks for the info.
I mean there is definitely a lot more to it than that… but in esk8 there aren’t even escs capable of pushing amps that high so🤷♂️
Yes. I only needed info on the esk8 area. I only know how to restore power tool batteries.
Thanks a lot. Appreciated.
