Forgive the noob question but will I be able to fit dual outward facing 6374 bkb motors on quick 66 mounts on surf rodz trucks without hitting?
200mm trucks obv
What mm axle for SR? But yes they should fit.
80mm axle.
Should fit no problem.
Thanks brother I only ask cuz the Bkb are 84mm
So thats 148mm of motor. As long as your mounts arent more than 25mm thick, you should be fine
Not the quick 66 but 6374 bkbs on 200mm surf rodz and 90mm axle.
Tiiiiiight
Jelly
