Do you plan a huuuuuge enclosure? Too much connectors here…
I don’t like XT90 connectors at all, they are too big and you don’t need them, also you can’t bend the cables the way you like (the same problem with XT60).
I prefer single bullet connectors so you can route the cables any direction. I like 4mm bullet connectors (90A), the same as in XT90 but nice and compact, or 5,5mm bullets (140A but big).
But one picture speaks more than 1000 words…
Ok, first of all, your wire diagram shows discharging through the BMS, THIS IS NOT BYPASSED and you would damage your tiny BMS immediately, or at least it would shut off everytime when you pull the throttle!! You need to connect discharge minus to battery minus, now it’s only connected to C- /P- on BMS.
Like this:
You can plug plus of Lipo 1 directly to minus of Lipo 2, this is what i do, it’s 5,5mm bullet male/female.
If you put BMS and charging port in the battery section you can save cables and space.
5,5mm bullet connectors for charging cables is way too much, i use 3,5mm (still too much). And 18AWG wire for charging and BMS connections is enough.
I think you’ll use to much cables, keep it short.
DON’T USE THIS POWER SUPPLY!!!
YOU NEED 25,2V LI-ION CHARGER, this is something different.
Also you need a fuse for safety.
I don’t trust Loop keys and you should buy an anti spark switch.
Esk8.de sell them for 29,90 free shipping, including fuse.
It’s so nice to have a switch!!!
It is dangerous to play around with Lipos and BMS, just one wrong cable and you could get in troubles ![:wink: :wink:](https://electric-skateboard.builders/images/emoji/twitter/wink.png?v=12)
