So I burned my BMS (which might be the cause of problem in the title) by plugging balance connectors with reversed voltages. I have a spare BMS, but to check if I got balance wires correct now, I’m still using the burned BMS (only the resistor by lowest voltage balance wire port got burned. I changed the balance wires and plugged everything again into BMS, nothing else is burning thankfully, but voltage meter doesnt light up and when I checked discharge port with multimeter it showed 3.6V which should be 10x bigger (10s battery)
Is this due to that BMS is burned or I wired something wrong?
My diagram:
Diagram by bestech:
One thing to note, I just assume those wires are e-switch and I just wired them together.
How can you check if a resistor got burned ? I have also plugged in balance wires in wrong order and now during acceleration my bms shuts off. Shall I probe resistors with multimeter and check if they are same resistance ? Shall I have motor running during this process ? If it is a small resistor I would be tempted to replace it myself.
