Hello, i want know if bms from china (aliexpress, ebay, banggood) is good enough for electric skateboard. and if you have do you have some problems?
thank you for yuour time
Several times, I have read on this forum something like : âYou can buy a cheap power supply but always take a good BMS anywayâ.
My own experience :
I bought a BMS from aliexpress last year (20 euros), it worked for a long time but then I used it a bit harshly (outside of the skate, without any case, so totally my fault I guess) and a resistor burnt.
2 days ago, I ordered a cheap BMS from ebay just because I need one quickly but after the event I need one for, I will buy a good BMS from Bestech or BatterySupport.
My advice : Get a good BMS
It is not a Matter of stores. Aliexpress has a lot of garbage and also very good bms. Depends on the model/manufacturer/sellerâŚ
Thank you, and another noob question, you can control output of bms like voltage and amp, or bms have to be a specific for your type of battery and your xP exemple: 12S1P
It has to be specific for most cases. Some Smart bms can tweak parameters via pc or phone. Depends on the bms. 10s 20a 6$ for example⌠Thatâs exactly what youâve got. The only choice available is bypass the bms. I do not recommend you that option if you are still unfamiliar with the bms world.
thank you, i searching about bms. and i understood bms have a limited discharging, so, if the discharging (from battery to vesc) max is 20 A is useless have a VESC with max discharging 80A because my max will be 20A
like this
Exactly. That one could be used only bypassing the discharge. Or used like that with a very low performance. Also make sure you understand the difference between lifepo4 and lipo/li ion. They have different voltages so they are not compatible. That one you posted is lifepo4. Good for street legal ebikes.
I use cheap BMS as @Blitz said. But I bypass discharging, and use them for charge only.
I donât use discharge bms for various reasonsâŚ
@Deckoz Iâm new to bmsâs. I have a $9 bms from china and am really worried about using it. I actually used this video https://youtu.be/_yrYG5skwvs to help me connect my power switch and vesc to it. Is this setup to bypass discharging? Sorry to sound like a noob!
Where can i learn more about bypass? i gonna need a 12s bms soon so i should probably research
All you got to do, is make sure that your charging wires are connected to the BMS. Either to the C- or the P- on your BMS depending on design, since some BMSâs donât have separate charger/VSS ports. Then solder 2 ground wires from your battery to the BMS B- and another to your anti-spark/VESC. Then your P- or C- to charger port.
