30a for charge only or 60a for charge/discharge
I guess I will buy that one right now, probably even if I figured this one out its very low amperage. Also, the positive connection for the battery on the board doesn’t even touch the bms at all, it just bridges the charging port and the battery positive. Thanks everyone!
This 6S BMS only needs 5 pins, because it has both B- and B+ ports. My BMS doesn’t have B+, so it needs as many balance pins as it has cells
This board is labeled “B1, B2, B3, B4, B5”. B0 is redundant because it is B-. Similarly, B6 is B+
This from the post just prior to yours. This BMS is not a good design.
