I know I have to connect my Negative wire from the end of my pack to the B- on the BMS
I have to connect the negative lead from the charge port to the P-.
So then I’m left with the positive wire, that goes to the anti spark.
My question is do I run a negative lead from P- to the antispark as well?
N- remains unused. P- and battery plus both go to the charge port and to the antispark. Minimum 12guage for the power connection and maybe something a bit smaller for the charge port connections.
Ok so balance wire voltages spit on. Have wired the negative from the battery to the BMS B-. And wired the charge port negative to the P-, with a negative wire that will connect to the antispark. It’s ok to put the charge and he blows wires into the same bms P-?
