ive got a charge/discharge bms 12s 80a (http://www.batterysupports.com/44v-48v-504v-12s-80a-12x-36v-lithium-ion-lipolymer-battery-bms-p-392.html) so I am right now into connecting that whole thing. The balance wires are no problem. I watched a ton of videos and read much but I am still not quite sure. Ive made a photo of like I think its correct but the cables which go to nothing are confusing me somehow. Maybe someone could help me a bit I would be more than thankful!! No worries its just sticked together to show.
So there is the negative and postive from the balance plug where they go? I think i have to skip the second postive of the second battery and the negative goes to b-?
Ok so the balance wires I ordered like this, i started measuring the pins and startet with pin 12 - into small positive balance plug at the postive side of the “positive” battery - 44v. Then I went through all and on the other battery “the minus one” which is in series I skipped the first and last pin because I assume they are conected anyways with the big wire. The rest I left like in my last photo.
I always see you mentioning the importance of putting a fuse on the charge port and I totally understand why, but how do you do it? Never wired a fuse before I’m sure it’s simple but I’m a visual learner. Do you have a photo?
Thats how I would connect it. Hope you can see everything. Also a photo of the top of the bms (not connected to anything).
I drawed no xt90 connections or sth like that.
I think its correct. But not sure
how do I check the voltages correct with the mulitmeter if the battery is in series noob question but never used a multimeter before and I think i measered wrong
You have two 6s batteries, let’s call them 1 and 2. Let’s say all your cells are exactly at storage charge, 3.7v. Let’s also say that your pack negative (ground, 0v) is the negative on 1. The positive on 1 goes to the negative on 2, and then the positive on 2 is your pack positive (+44.4v.)
Each of your 6s batteries has 7 balance wires. One connected to negative, one to positive, and one in between each pair of cells. Since you have two of these in series, then the middle wires are redundant (the positive-most balance wire on 1 is the same as the negative-most wire on 2.)
After you take this into account, you have a total of 13 balance wires for the pack. One to negative (ground, 0v), and one to positive (44.4v), and one between each pair of cells.
With that BMS, the wire that goes to the spot marked 1 on the connector is the second balance wire (measuring from ground, 0v, it will be 3.7v.) position 2 gets the third wire (measuring from ground, it will show 8.4v.)
Repeat this until you get to the end, where the 12th position gets the thirteenth balance wire (44.4v measuring from ground).
The side where B- goes into the battery at the outside is supposed to start with 3.8v at the balance plug according to the plan. But I already have the 44v up there. On the other battery where the outside is positive I have on the 2nd pin of the balance plug after the red cable 3.8v. But according to the plan should be 3.8v where the negative b- come in. Or does it really matter as long as I measure? I hope Iam not annoying already. But really want to learn that and not connect anything what blows at the end.
Yes, either one. I put it on the negative so it’s easy. If you put everything on the negative then you know all the positives for everything just connect together. Less complicated.
charge port is not soldered but the big wires are ok so, arent they? Watched the schematic and everything should be correct I think. Maybe someone can take a look
lipo conects at the right xt90, vesc at the left one
You’ll need another small red wire coming off that big one for the charge port. I can’t see the “B-” and “P-” labels so I can’t confirm that is correct
Make sure B1 is about 4V more than B- and B2 is about 4V more than B1 and B3 is about 4V more than B2… etc
