Hi guys,
So i need some help wiring a switch to my BMS,
I have purchased the Neptune Lite Smart BMS, its for 13 S but has a 12S converter aswell, i will be using 12S.
This is the schematic from the website:
And this is the PDF file: https://drive.google.com/file/d/0B5VoC0prU-ShRHdLSnlKUDNKbWM/view
Some questions:
I will be connecting this BMS to dual Focboxes, do i need to buy an Anti Spark Switch? or do i need to just buy the switch? since it has the switch connector port on the BMS.
Where would i connect the charge port on the BMS?
Thank you
That smart bms is specific for ebikes. I guess it can work for esk8 too. Check endless sphere. Tons of comments about it.
Yea mate you are right, another member here has used it for 12S lacroix diy build also and works fine. I messaged him about it.
Eskate444:
Anti Spark Switch?
I think you may need one.
I don’t think such a small bms can handle the discharge current.
Is rated for 59 amps. It has some reputation at endless sphere. I think the discharge could be legit.
rojitor:
thats really good. was looking into it for my 13s build…
