Hi, I’m using an external BMS from my board. I think I add a nano fuse on each of my balancing son in case of short circuit of my external port. I know that normally the wires are fine and must behave like fuses but I prefer a clean break using dedicated component (I will take 2A). Here are my two questions: What is it best to connect the balancing wires first and then the power cables or the opposite? for now I connect the power cable first.
Second question: if I connect my BMS when one of the balancing cables is cut (the fuse jumped for example), will the BMS handle the situation?
