I recently installed a 15A D140 BMS on both my boards, but I just noticed that my charger seems to be overcharging my batteries by .1 to .2 volts when I look an my battery meter I have installed on my board.
I have heard that the charger is responsible for stopping charging as soon as the battery is at the correct voltage, so is this an issue with my charger? It is just a cheap 2A charger I bought off eBay.
I have a 12s setup with 4x3s 8000mah Zippy Flightmax batteries.
@telnoi I just checked with a multimeter and It is reading 50.5 volts at the moment. I plugged it back into the charger and the charger still has not turned itself off. I also measured the voltage on the charger and it is 50.7 volts. How dangerous is this realistically?
Just as an update if anyone else ever has this issue, I read a little more about this and it turns out charging each cell less than .05v above 4.2 really isn’t that big a deal. It might slightly lower the life of the battery but not significantly enough to matter. Also BesTech D140 BMSs should protect the battery from overcharging more than .05 volts. In the future I think I’m going to buy a little bit better quality charger though.
