Hey, guys so I want to build a super long range esk8 on a spud or a Tayto, I’ve talked about 10s6p on a previous thread but @Eboosted updated the spud DS enclosure to be able to fit 12s6p…
Now just a very simple question (not) how much would the board weigh? the parts im thinking of using.
Fatboy Nano on E CalibersMaytech 6355 sealed12s6p (72 Cells) (i have enough cells)
Focbox unity (i have on preorder)
Tayto or spud (i have on hand)
Eboosted Spud DS enclosure
Abec 11 107mm refly
I’ve done some rough calculations on weight but couldn’t find info on some parts (used the search bar a metric shit ton)
12s6p on LG HG2 cells are roughly 7.8LB
2 maytech 6355 are roughly 2.96LB
Abec 11 107mm refly roughly 4.45LB
Brings the build-up to 15.21LBS
I need help finding the weight on the rest of the parts…
I have the same excat setup - the battery. I’m running 5 2s lipo’s and my board weighs 21lbs. Even if you subtract 3lbs for my battery you will end up with around 30lb board.
You will be buff in no time. Just start curling the baord
It looks like it will be close to 26lbs…If you’re gonna be carrying up and down a dozen flights of stairs a day you’re probably wish you went for a slimmer battery
in fact i have a 10s5p pack coming right now, and im gonna be strapping it onto a 33 inch deck with tb dd (but using hummies hubs for now when they come.
Long range and lightweight do not play along together. Get the 12s3p with kegels, pretty nice lightweight board I ride it myself when I go to places where I need to mall grab it.
Otherwise I like to ride my 12s5p sidekick
Or get the 12s6p, 100mm boas and forget about the weight
I care a lot about weight. That’s why I have short range boards and long range boards. On the long range boards, weight is not a factor in the design. On the short range boards, it’s a bigger factor. But not such a big factor as to not use humongous wheels.
For a 72 cell board, it’s going to be super-heavy no matter what you do. You really, really, really will want some sort of kayak handle or fabric handle and balanced in the center of mass along the board.
If you have to have long-range, and weight is an issue, that pretty much means you should go single-motor. Have you considered a single 6374 on the rear heelside? A 6374 is heavier than a 6355 but it’s definitely lighter when you don’t need the other motor, you don’t need the other motor mounts, and you don’t need the other ESC.
When you arrive at the destination, curl it. When you arrive home, curl it. Bonus points for doing it while standing. You will BUFF your hand in no time.
(Just make sure to take breaks in between the reps. )
It’s common for first builders to want to build the first eboard with all features:
A very long range battery but keeping the esk8 realy light
Get the best parts in the market but keeping budget low
A very high top speed with a monster torque
A huge battery under the deck but it must look sleek
A board with streets wheels that can be swapped to AT easily
However, as everything in life, success is archived when you find the balance, the best eboard would be the one that suits your main gol, do not try to score everything or you will be derailed soon.
