Now updated and more reliable than ever, there has been a good amount of improvements.
-V2 Clamp with 2 piece bolt-on instead of set screws. A significant amount more reliable and won’t bite into your trucks
-Updated dimensions for better fitment and unity among products
-Stronger 12.9 Grade hardware for a strip-proof experience
-Brand New Non-Idler designs
-Better manufacturing processes, smoother finish and less lead time
You can buy here on www.boardnamics.com, my new website that is heavily under construction. Fully functional and ready for ordering
There is a lot more information on the website, but here is a basic overview:
-Compatible with Caliber II trucks
-Comes in 50mm, 63mm, and idler version
-CNC Machined and Waterjet 6061 T6 and 7075 T6 aluminum respectively
-70mm ±8mm center distance (Ideal for 265mm belts
-Fully angle adjustable and able to be flipped
Any questions and concerns feel free to message me on here or email me at [email protected].
I had a similar clamp on design like your mount.
Problem here is the screw facing the street:
Keep it as narrow on the trucks as possible - best way is to have it facing parallel to the street!
You´ll be hitting rocks and other stuff and this will wear down in under 500km.
Worst case, you face the street because you catched something big - happened to me with this.
Will these work with the racerstar style motors 5065 size? I know the mounting hole spacing is weird on them. I also apologize if this has already been answered a million times. My reading comprehension went to shit after my roaring twenties.
Unsure. They fit perfectly on standard calibers. You would have to do a little filing. The “pro” is that since it’s a 2 piece set, you only have to file a portion of the hanger, not the whole thing to slide a 1 piece clamp on in comparison.
For the idler setup, the 2 belts I include, 320mm and 325mm will cover this ratios. If you are using big 107mm wheels though it might pose an issue as it blocks the idler.
320mm is good for 36t pulleys, 325mm is for 40t.
If you want to source your own 15mm ones then yeah hope that helps. Thanks
