M1 Gear Drive
The final version has arrived. The M1 stands for Module 1, the size of the gears
Price is 159.99USD for a dual. $229.99 for a dual + 220mm hangersSingle drives will be $89.99
Specifications:
Materials: Hardened alloy steel gears; all components machined 6061-T6 aluminum
Gears: Straight cut only (for now). Helical coming soon. Ratio is 2.8
Wheel compatibility: Kegel, Flywheel, and Bergmeister
Hanger compatibility: Boardnamics 184mm, 220mm, and 270mm precision hangers ONLY
Clearance: The case is 72mm in diameter. 97mm wheels or bigger recommended
Very happy with how these turned out. Extremely low rolling resistance because the seal is a unique bearing+o-ring combo. Amazing sound, like a sports car Excited to share them with the world.
Matrix II MountsPrice is $79.99 for a set(2)
New version has arrived with a few changes:
The overall quality is significantly higher than V1. Sandblasted black anodized.
Optional holes for Idlers
44T Kegel Press-fit Bearing PulleysPrice is $49.99 per set (2)
Same reliable design as my other bearing pulleys.
Compatible with evolve boards with optional 10mm bearing
ETA 1-2 weeks
Steel Motor PulleysPrice is $8 per pulley
Material: Black Oxide Steel
15mm wide, keyway included
2 M5 set screws
No shoulder
14T, 16T, and 18T sizes
