Iโm sure you could find a way to cool the wires as well. They dissipate heat fairly quick
so much effort for that โฆ
Maybe using it only for iron soldering ?
ambidextrous?
edit: ah you have friends
The solder iron should work perfect. Is it so expensive shipping it back from your country?
Return and back shipment yes, Half of the prise of the welder. And we all like DIY no ?
@aulakiria: maybe i found a lead to teh problem. I took a picture before reassemble the PCB. A track seems to be damaged, it could be the root cause of the problem donโt you think ?
Due to lot of solder/desolder (and the fact iโm not a super skilled guy), tracks tends to be damaged โฆ
You are right. Check that the red markings that the electricity is flowing well.
So you can put solder a small wire huh? Interested to see if you get it going again, you are prety determined dude
Hey @aulakiria, I didnโt get the tip to the soldering kit ; I did just test out the spot welder and it is amazing though. Canโt wait to make some large packs with this.
Oh yeah! Back to spot welding
Epic repair!!
Iโm sorry. Please let me know your name.
Good. ^^ Is the weather warm? 29 degrees.
It uses the Arduino. ^^;
Warm where I live. 29 degrees as well on the welder
Hello, not warm but iโve done some weld to test it I will monitor closely the temp what is the max temp recommanded ?
I think max was 50, check his blog, it was mentioned there. That is, if he doesnt respond here sooner
Yep, recommended under 50
One of the few machines that can almost fix itself
