Hey e-Rider,
So, I got some stuff laying around from my move to my natal city ,
in Burgundy (Bourgogne for the amateur, yes Chablis, Pinot Noir, Chardonnay, Beaujolais etc.)
Then, they are some parts that I want to reuse with some new one!
Here I just want a cool little all road cruiser I will remake an e-MTB to go shredding the vineyard, so this build should be more compact, but as fun and maybe even lightweight and somehow easy to use without binding and top-deck enclosure.
- The Deck :
I come out my old deck to put it forward again! The SWE : Custom deck 7 wood plies + 2 CF + around 10 FG and CF layers for the integrated enclosure.
Edit :
- The wheels :
Brand new Bergmeister All-terrain pneumatic (precision CNC milled three-spoke hubs in mat grey/black finish … beautiful ) by Haggyboard.
The tires is 145mm diameter (and 46/47mm widest), and the rims come with a 22mm bearing seat that can fit all standard longboard/skateboard trucks with 8mm or 10mm axles!
- The trucks :
Supercarve … Because I would profit to test my mount (would love the Kahua trucks,… but also got the TB218 still laying somewhere around that should be a lot better).
- The motor mounts :
Custom for Evolve Supercarve GT trucks, made from 5mm AL7075, for the front.
Reversible in every directly (rotation and mirror), 50 and 63mm motors (made for the MAD SURFER AWD setup), and with a dual idler or reinforcement bars.
And standard Evolve one for the rear :
- The Drivers :
DIY ISO 06B chain kit 9 x 26T.
I make a centered master from 3D print, to help me drill the sprocket approximatively well centered (only 3 holes to do ^^ … x4!).
Then I made a spacer with a bearing seat :
- Motors :
My fav since more a year, Overion 6374 130kV from the old Darth Vapor. Never failed, robust, always tonnes of torque. But thinking more about this it could be 5065 again for lightweight.
Edit :
Finally, I go 5065, cause I will be an AWD :
- ESCs :
Dual FSESC4.20 from the Mad Surfer… (perfect for my deck and it will force me cruising as I got a small battery).
Edit :
For the quattro and this little motor low kV I choose the classic VESC 4.12 :
[ insert photo]
- Battery pack :
10s 5Ah 20c slim pack (5 x2s), same as the original SWE setup (one day I would like to make a 10s 3p VTC6 pack if it feels good).
Edit :
I will try this sweet little beat under 12s with the vesc ,… I don’t charge more than 50v and with the 140kV 30Amps batt max it should be fine … I hope
So Lipo pack 12s 10Ah 40C ((3x4s)x2)
[ insert photo]
- Remote :
GT2B as usual (since my 1st build, and on almost every setup I have made for me), MadMonkey mod with ch. 3 made by Pimousse.
- Modules :
Metr.Pro PCB antenna, the best friends of my phone now I didn’t get any issue with it (my phone!).
- Enclosure :
to follow …
Summary list of parts :
- Deck : Arbor Axis Koa 40"
- Trucks : Supercarve for now…
- Wheels : Bergmeister All-terrain
- Transmission : DIY chain Kit 9 x 26 T iso 06B
- Motors : Racerstar 5065 140kV
- ESCs : Quattro VESC 4.12
- Battery pack : 12s 10Ah 40C, from two pack of 5Ah20c in // with 4s 5Ah 20c Lipo
- Remote : GT2B
- Module : Metr.Pro
I will keep editing
Enjoy & Ride Safe
