Bowery Surf Launch! - Adjustable Baseplates for TorqueBoards DD, Raptor 2, Caliber 2 & SurfRodz
Hey everyone!
In stock and shipping now. This batch I only made them in blue and red since that’s what got the most interest, but I’ll have a few more colors to choose from in the next run. If you PM me this holiday weekend, I’ll send you a discount code for free shipping if you’re in the U.S.
I’ve got a bunch of the adjustable baseplates ready to go out.
These are designed to fit:
TorqueBoards DD
https://bowerysurf.com/products/adjustable-baseplate-for-carvon-torqueboards-direct-drive
Raptor 2
https://bowerysurf.com/products/adjustable-baseplate-for-raptor-2-2-1
Caliber 2
https://bowerysurf.com/products/surfrodz-style-adjustable-baseplate-for-caliber-2
SurfRodz.
https://bowerysurf.com/products/adjustable-baseplates-for-surfrodz
Excellent, have not been able to get adjustable baseplates from Surf-Rodz RKP forever! These look awesome and will slow me to finally get some of these hub motors onto different decks, like trampa and @kaly etc!
Heading up to see @kaly this weekend!
Rad dude, looks great
Awesome set up
Thanks @mikenyc
This things Rocks
I’m tempted… But
34zzvr
What configuration are you interested in? TB/Carvon, Caliber, SR, Raptor?
Only a couple of TB/Carvon left. Running low on SR.
what would shipping to EU (specifically netherlands) cost??
you should be able to add it to your cart and then get a shipping cost when you check out
~ 35 dollars. thanks! i saw the green ones for caliber are sold out. will they be available again soon by any chance?
ah yeah, depends on how quickly this run sells out. purple goes well with green though, kind of like the joker.
Wouldn’t the Caliber one work with Carvon because the hanger has the same geometry?
There’s a 1mm difference in the position of the kingpin.
RenderedImage
I wonder how much height is added to the raptor baseplate over the stock ones…
My calibers adjustable baseplates are about 14mm taller than my fixed baseplates. @drangboards Which just happens to be like the exact size Riser I was using. Still getting some things adjusted just wanted to get them on to see how they fit. 20190720_000859 20190720_061210 20190720_061157 20190720_000656 Quality is top notch. cleaner than my surfrodz tkp one. I’ll probably use them on a different build seeing this is a slower budget build. But they cam in the mail and i used to test them out.
@mikenyc what lenght bolts should work with these plates for surfrodz? To my shock, the stock ones are waaaaay too long.
2.25" Surf Rodz kingpin, but you can also use a regular kingpin with a mtb bearing or axel spacer. You would put this between a flat washer and the head of the kingpin. Trampa sells a bunch
Do we need to loctite the SR kingpin? Or does the bushing compression prevent it from backing out?
Making more plates for SR anytime soon?
