i made a build with two generic 90mm Hubs which are available from many Chinese sources.
I did set them up with two Vesc´s in FOC mode. Everything is working fine except the brakes.
I will get brakes for a split second and after that the board just coasts. If i pull the trigger just slightly i get brakes for a longer time but they will cut out either.
I run them on a 10s5p Samsung 30q pack which is not fully charged.
My Vesc Settings are.
Motor max 60A
Motor min -60A
Absolute Max 130
Battery Current Max 25A
Battery Current Max Regen -20A
Thanks for your reply!
I installed the latest firmware on them, @psychotiller confirmed that even the Maytechs can do FOC now. I am still hoping that it is more a setting kind of thing.
I did in fact confirm that 3.3 likes foc. What version vesc do you have? Changing the firmware on older HW isn’t going to make unicorn sounds come out of your older maytech vescs…
I bought them in December `17, 4.12 HW. They still have the old stickers on the transistors not the blue ones for the Super Vesc, are they too old for FOC?
Yeah…The newest 3.3 versions are FOC solid. No guarantees on previous offerings. (Though, I have had a couple of older versions that didn’t burn up using FOC.)
Try lowering your regen settings, and “Uncheck Limit erpm with negative torque”
