Setup - Enertion dual motor kit with VESC and PRO4 battery pack
My problem comes when I am braking at high speeds. The breaks completely shut off for about 2-3 seconds and the board wont respond to any input. Braking at low speeds seems to be fine.
I’m wondering if this can be a simple fix in my VESC settings? brake limit cut-off or something?
I don’t think its the VESCs overheating. It happens immediately when starting the board cold. For example… (Turn on board, run motors, hit breaks… the breaks cut out even when not standing on the board)
Further explanation is that when you brake there is a voltage spike due to the motor generating power when braking, this triggers the VESCs protection and forces it to reset that explains the 2-3 seconds which the VESC does not respond to any input because it is going through a power cycle. After it boots up it works until you brake again.
EDIT: this does not happen at low speeds mostly due to the voltage not crossing the threshold for the VESC to reboot.
I dont think there is, at least for esk8 applications. Maybe it is there so that if someone wants to push the limits they can increase it or something.
I have never encountered a situation where I had to change it
