Does anyone know if using a copper braid such as this one from amazon will allow for a solid connection between cells on a 10s4p battery?
What do you use as a preferred connection?
I tried to use that method - it wont work in this specific build due to soldering the strips onto the battery. I have the necessary spot welder now, but it will not work with this setup due to the soldering.
