Would it be possible to make a longboard using two of these: https://www.vexrobotics.com/217-4347.html brushed motors. They have a power output of ~350 W per motor, They would be run with 70mm wheels and a 3.75:1 ratio per motor.
I am not too concerned with efficiency and range at this point. Here is a full chart of its specs: http://motors.vex.com/vexpro-motors/775pro
Has anyone tried to make a board with brushed motors? Any feedback would be great!
Ah! I remember these motors! My robotics team and I were amazed at the performance increase over the standard 775 motors. Vex products are great, however I doubt that this would be even possible for an esk8 application.
For one, the shaft is much too small to mount one of the pulleys that people usually use for boards on, and I think it is quite underpowered. When we used these motors for our robot, we had some pretty large planetary gearboxes on them, and while you could gear it down for an esk8, I doubt it would be enough speed or strength to effectively move a person. Also, the esk8 motors are all way more powerful than this, clocking in between 1000 and 3000W of power.
Hey @MoeStooge what U think?
@ShutterShock, I wasnât sure if 700W was enough for a basic application with reasonable speed, I was just planning to use a Spark for speed control.
Do you have any experience with buying parts in Canada? Hobbyking is quite challenging in Canada for many reasons. This was the main reason for using FRC parts.
Iâm in Canada as well so I feel your pain. I get a lot of my stuff from cause they have free worldwide shipping over 300 bucks, plus their well established and have good parts.
As for hobbyking I havenât had too much trouble. I believe you need to order from their US warehouse for batteries though.
Honestly I am not super sure. It may be enough to keep you moving, but I would imagine that you would have to push start it. It sounds like a cool project to me, maybe with the more extreme gear down, you would be able to do it.
Unfortunately not, I live in California, so no problems with HK shipping for me. I never even thought to use FRC parts. One of my friends suggested using a CIM motor but those are super heavy haha.
If you are able to calculate the kv of those motors, you may be able to use the esk8 calculator to figure out some more detailed potential. ÂŻ_(ă)_/ÂŻ
Esk8 Calc
700w not enough pwr. You would have to run a reduction Jack shaft and would go 8 mph to keep from melting it down.
Yeah that is what I was thinking would happen haha, if it doesnât melt before getting to that speed.
Theyâre great for robotics, probably not for esk8. The CIM is a possibility but the watt rating on it is only 300
