Hi, I am trying to build my first e-skate board. I’ve had some help from a friend along with the use of research within this forum and online. However, I’m not confident in knowing the compatibility of the parts I have found. I’m open to any suggestions or comments on my current parts list.
I’ve yet to choose an enclosure since I’m unsure of what deck I would like. I was thinking about going with the loaded poke as I will be mostly using my board for commuting within the city, but would still like to use it for longer sessions. As well as this, I like the kicktail this board has since I am also a skater. What deck do you think would best suit my situation, over the loaded poke?
Any help would be great, thanks!
trucks | 2X E-Caliber truck * |
wheels | Orangutang cauama 85mm |
VESC | Focbox Unity |
Motor | 2x SENSORED WATERPROOF MOTOR 6355 |
Motor mount | 2x Caliber mount * |
Drive piece | 2x 36T 15mm wide aluminum pulley with integrated bearing for kegelcore, 2x 15T aluminum motor pulley * |
belts | 2x 270mm HTD5M belt 15mm wide * |
enclosure | |
controller | Focbox piolet remote |
Battery | 10s4p |
stared items * - Dual Mechanical Kit (save 20%) – ElectricBoardSolutions
VESC - Focbox Unity | Powerful Dual Motor ESC for performance electric skate – Massive Stator Pty Ltd
Motor - SENSORED WATERPROOF MOTOR 6355 – ElectricBoardSolutions
Controller - Focbox Pilot Remote | Compact Rechargeable Wireless Hand Control VESC – Massive Stator Pty Ltd
Battery - Molicel P26A – Fogstar Wholesale (fogstar-wholesale.co.uk), Flexible battery PCB kit – ElectricBoardSolutions, Bestech High Discharge BMS 10s/12s 40/60/80A – ElectricBoardSolutions
