Ah no sorry, I didnât mean that 12s1p wouldnât work because of too much voltage. I meant I was told it wouldnât work because of being too weak in amps and suffering from too much sag. (just repeating what I was told, I was surprised myself as it should have more available amps than liion).
The 12s1p seems to work out the same weight, and ÂŁ30 cheaper, than an 8s4p liion. The liion has a lot more range, while the lipo has huge discharge and charge rates.
Thing is, nobody seems to have weighed in with how much discharge and charge is actually -needed-. I thought a VESC had a limit on the max voltage it could handle, so wouldnât 250A be totally unecessary? If the VESC can only handle 60A at a time, then wouldnât the 60A and extended range of a lion pack be more efficient? (I really donât know, these things donât seem to be part of the equations on this forum lol)
What actually is the number of amps charge rate required for consistent reliable braking on an eboard? It would seem like a figure everyone on here should know off by heart, but instead it seems like nobody has ever worked it out. It certainly hasnât been obviously written in any of the noob guides (I seriously doubt Iâve missed it in all my reading).
Liion 8s4p gets 12A, LiPo 12s1p gets 25A. Which would imply that LiPo would be more reliable for brakes. Except if braking only ever needs 6A or something, then itâs completely irrelevant because both packs will handle it easily.
did some more research before finishing writing this post
After further research, it seems braking with -8A on battery and -50A on motor should work decently? So again, LiPo seems to add excessive charge rates that are never used, at the expense of range?
Dont get me wrong, Iâd prefer to use a LiPo 12s1p if it worked out giving more torque and braking ability like it implies by the ratings, but it seems to limitations are in the VESC (and also the ability to actually stay standing on the board).
Plus, I wonât be using the board every day, itâs likely it wont be used for a few days or mostly be used at weekends. And it seems LiPo will require much more supervision and being discharged for safe storage and only charged on the day of use. And being charged and stored in explosion/fire proof bags or ammo boxes, apparently. Which is fairly scary.
Honestly surprised there doesnât exist a battery that doesnât burn down your house just by being charged lol.
