so to start of i’m 16 years old and don’t know to much about electics I want to build a board and have done some research but I still want to know if my setup works or If there is anything I can change. As you might imagen I have a pretty tight budget and I basically just want a cool board to travel with. I have almost zero boarding skills but my tec teacher and father are good with electronics so they can help me build it and I have watched and read lot and lots on this forum. You guys are awesome! but yeah I just want to know if this setup works or I should change anything. Any comment welcome
Looks good! The only thing I see an issue with may be your choice of ESC. Not sure what they are charging but, you could do much better with the VESC or even Hobbywing with the Max 6 esc. Reliability is a factor and will double your cost on an ESC pretty quick.
Thanks for the help super nice of you. Is this the one you mean or is it some other one?
http://www.hobbywing.com/product_show.asp?id=205
will my board burn up or something or am I in the clear of that? XD I’m a bit scared XD
I try to say this to everyone i see on here who is just starting out: Don’t forget the thread locker!
Good luck and congratulations on starting your new build! Soon you will wonder how the hell people can say they are living life and not ride a four-wheeled electric rocket stick into funville every day.
In order to make the “E-board Builds” category really easy to search & locate specific builds i am asking that you change your title to something descriptive that better expresses the makeup of your build.
Most of the new build threads tend to end up with a name such as
"new- noob - noobie - beginner - first - build - help - newb" this becomes hard to keep track of.
I would like to see each build thread with a descriptive title, such as;
Project Name | Deck Name | Trucks | Motor type | Mounting method | Voltage/Battery | ESC
Example
The Samurai | Custom Deck | Paris Trucks | R-SPEC | Custom Mount | 10S | VESC
