I’ve started spot welding my battery pack and the positive side spot welding has gone really well. Good strong welds.
I did some tests on spare cells on the negative end and I can’t get a good weld. I’ve turned up the time but I don’t seem to be getting a better weld.
Anyone got any tips for welding the negative end? Do you prep it by sanding or anything?
I might need to re-wire my spot welder as I tried joining two pieces of 16mm2 cable and I think the join is bottle necking it.
I had similar trouble when I was spot welding my cells in parallel the other day. Positive side went fine after initial tinkering. Negative side kept giving me trouble. I’m not entirely sure that the welds are good enough to pass a strict criteria but I think they are fine. What I had to do to make them better, because just amping it up wasn’t enough, was upping the multi-stage multiplier. Or reference, I’m using boss level spot welder.
To make the join I just meshed the cable together and tried to solder as much as I could, but my soldering iron isn’t very powerful.
I’ve ordered a longer length cable to rewire the whole transformer.
I’ve been using copper clout nails as my probes
Cool, same as me. I ended up filing mine to a sharp point every 20 or so welds. If you weren’t already doing that it sounds like yours held up better than mine. Maybe just try changing to some fresh nails?
I’ll try that.
I’ve also order a strip of 60A choc blocks, I’ve currently been using the 30A ones and they get pretty hot after a dozen welds in short time.
Even in factory made welders oxidation and heat will corrode and flatten your points.
A little sandpaper should keep it clean.
Heat will also effect your welds. Keeping everything cool will help. Even a fan on the trans will do the trick.
Parts arrived and I’ve rewired the transformer. It’s comfortably spot welding nickel to nickel now with a fraction of time it previously required so it appears as though the power has jumped significantly.
I’ll be getting back to the spot welding over the weekend weather permitting, I’ll be doing it outside in case I burst a cell.
