Before I purchased the VESC, I used the trackstar ESC (on the black board now). I made a guest e-skateboard because skating with a friend is a lot more fun.
I recieved my wheel and trucks and I need to choose 12t timing pulley for the motor, 30t for the wheel and also a timing belt.
which one should I use ?
thanks
this is the wheels kit
You can probably use this for the gear pulley.
Ebay
I’m not sure how to mount the wheel pulley to those wheels. All my wheels 83mm with plastic hubs. You will probably need a belt that’s 260-280mm diameter (depending on what motor mount you use).
