I then made 4 enclosures from some 2mm HIP A4 sheets. I’m well chuffed with the results. Most probably would be better if they were 3mm but I’m not sure how they would form.
I then filled the holes on my Trampa holy pro deck with 3mm plywood and bonded them in.
Yeah it’s Liions pack. I changed the shape as it was in a block configuration which sat in a battery box on top. I just cut them up in to each block of 4p and then used silicone wire to join them all back up in series.
I was stumped when it came to enclosures for the trampa. The one that tramp sell would be ideal but appears to need a fair bit of work to use, and I couldn’t find any others on the market.
Cheers, Yeah i’m sure if your doing proper mountain board riding its better to have the batteries on top and out of the way. I only use it for urban and light off road so it will be perfect now.
I bought a small sheet of 9mm plywood £9 and used about half of it.
3x 1 meter lengths of alloy angle £ 3 each,
I had the small angle brackets but they are not much, it took about an hour to build.
